Old 02-04-2015, 04:48 PM   #201
sojourner's Avatar
Engine: DT408
Framed in the driver side center section and the passenger side rear sections. Gonna put the batteries for the solar system in the rear passenger side.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 02-04-2015, 04:57 PM   #202
sojourner's Avatar
Engine: DT408
Originally Posted by Outcast View Post
Reply to post #177
Walter Wade runs the shop, and drive for the county school system so you have to catch him between runs. Let me know exactly what you are looking for and I can have a look and take some pics, I live right around the corner from his place and go their quite often, as you might imagine.
That would be way cool. I'll PM you.
Old 02-05-2015, 07:08 PM   #203
sojourner's Avatar
Engine: DT408
Framed in the passenger side between the wheels today. All total I used over ( 20ft. sections of 1-1/2" x 1/8" angle iron. Gonna need to get some more when I frame out the interior. For now though I have to do a few gussets built and in place and strengthen where the awning will be mounted. I'll also strengthen the storage areas. I won't remove all this and finish weld and paint until I get the door framed in after the roof raise. Gotta build the door frames for the storage and figure out how I want to do the actual doors. Gonna have several doors of various sizes.
Old 02-05-2015, 09:38 PM   #204
very clean work. I like it, very solid looking.
Old 02-06-2015, 08:12 AM   #205
sojourner's Avatar
Engine: DT408
Thanks. It's amazing just how solid 1/8" angle iron get's. I'm going to fill in the walls with 1/8" aluminum signs (I have out back) cut to fit. With undercoating on the outside and bed liner material on the inside and the panels sealed with 3M 5200 they should be pretty much water tight.
Old 02-08-2015, 07:36 AM   #206
sojourner's Avatar
Engine: DT408
Square vs Round?
I'm getting the materials ready for the roof raise. I need to get on this as every time I look at it I decide to raise it taller. The quicker i get to this the less likelihood I'm gonna put a second story on this thing !
My question is concerning the riser material. As it turns out 1-1/4" x 1/8" square tubing in crazy expensive. Almost $50.00/20' stick!! Strange as the scrap price of steel has been in the tank for some time. I know some have used round tube and I'm told (by my engineer son) it's even stronger than the square and less expensive. I know it presents some minor fabrication challenges but what is everyone's experience who have used square and round?
Old 02-08-2015, 07:58 AM   #207
Sounds like you've priced 11ga square tubing.
What about 14ga? I think it would be sufficient.
I don't know about the round vs square... I don't think it matters as long as you're willing to make it work. Square would be easier to work with I think.
I'm also really leaning towards doing a roof raise but can't seem to find much help these days...
Old 02-08-2015, 08:25 AM   #208
sojourner's Avatar
Engine: DT408
I hear you, I'm pretty much going to be doing this myself. Gonna use allthread as jacks at 4 places so I can adjust things on a micro scale as I weld in the replacement posts.
I'm thinking 1" schedule 80 pipe is looking very interesting right now. Here are the dimensions:
1"
OD - 1.315
ID - .936
Wall thickness - 0.179
lbs./ft. - 0.424
Yea I was looking at 11 ga. The pipe is a LOT cheaper than the square tubing.
The nice thing about using the thicker material (other than it's stronger) is when welding you can favor the thicker side a bit and flow in the weld to the lighter material without having to get in as much of a hurry to keep from blowing through.
Old 02-08-2015, 11:54 AM   #209
going too thick and heavy will introduce new weak points... Something to bear in mind. Also when raising, I'd think keeping the weight down would be a big plus.
Just some thoughts. I think saving money is always a good thing, too.
Old 02-08-2015, 09:16 PM   #210
sojourner's Avatar
Engine: DT408
I don't think weight on this is going to be an issue. A 3ft. section weighs less than 1.5 lbs. I may wait a couple more months though to purchase the steel. It's inflated right now and the price of scrap has been going down and will be reflected when the current stock has been diminished. This happens pretty much every year.
I wonder where someone might find any 16 gauge Hat channel like they make the bows from?
Old 02-08-2015, 09:20 PM   #211
YES! that stuff!
I'm going to see if my buddy who runs the brake dept at the shop will make me some.
Wondering how much it would be to skip that and just order it though.
Old 02-09-2015, 09:10 AM   #212
Back about a hundred years ago while raising a Blue Bird, I was able to get full repair ribs from the maker and cut them into what I needed. At the time, they were actually pretty cheap. Just a thought.
Old 02-21-2015, 07:17 AM   #213
sojourner's Avatar
Engine: DT408
Are rub rails needed?
I've been working on some access doors for my fuel tanks and stabilizer jacks. Building them from scratch. I'll get some pics of them later. While working on them I remembered a conversation I had a while back with a friend who's gonna do a skoolie and was asking if the rub rails could be removed and the whole thing skinned to look more like an RV. I told him I thought the rub rails were part of the structure but that was just a quick assessment and may not carry any real weight. As I think more about I'm thinking they just might not have that much to do with the actual strength of the sidewall as much as keeping the sidewall rotected and creating a handy place and way to deal with lap joints. I have a 1995 AmTrans and the profile on the side panels is a very shallow profile I assume to prevent oil canning. So the question becomes, are the rub rails actually needed? Could one remove all of them, have new matching skin made and re-skin the whole thing the same so it wouldn't look like a patch together job when finished with raising the roof? It may simplify things a good bit as the rub rails have to be cut and closed in where they cross doors and vents and such.
Old 02-21-2015, 07:29 AM   #214
That's something I've been thinking about lately. Good topic.
Would sure look sweet all smooth and new looking!
Old 02-21-2015, 09:03 AM   #215
Engine: 190hp 5.9 Cummins
I'm so glad you mentioned this.
Yes you could.
You also notice that near the middle of the bus body, right above the wheel wells, that sheet of outer skin had ribs pressed right into it? That's the profile you mention.
After reskining the sides of my bus, and doing a tin roofing job, I started thinking about contraction and expansion. Roofing tin has ribs pressed into it every 6 inches or less. I always thought this was just for strength, and rigidity.
Well it turns out both the roofing tin and the sides on my blue bird bus were both ribbed to give the steel somewhere to expand to without oil canning just like you mentioned.
So, for those of us who are reskining the sides after window removal, having a metal shop press ribs that match the rub rails into the new sheets would reduce the amount the new steel tries to buckle / wrinkle, and eliminates the need for rub rails.
One more advantage, is the fact that rub rails collect crap behind them, cause rust to start. With the new one piece panels with rub rails pressed into it, all seams will over lap the proper direction, keeping the water and road grime out.
The next bus I build, I will be reskining the entire sides, and implementing the one piece panels with built in rub rails.
Maybe I will even used polished stainless steel for a chrome look.
Slowly this site is evolving the skoolie conversions. Better idea's, Better methods, Better materials.
Just look at how many of us are doing roof raises now.
Old 02-21-2015, 09:13 AM   #216
Yes you could.
I thought the bus you have now and the 60k investment were going to last you a lifetime and be the end of having to buy stuff! What's this "next bus" thing?
Old 02-21-2015, 09:23 AM   #217
I have kids, and a bus addiction. There will be more bus builds in my future.
And it was 30k to 50k, not 60k.
Although by the time I build the 32 foot stacker trailer for behind the bus, I may be in that much. lol
Old 02-21-2015, 10:11 AM   #218
sojourner's Avatar
Engine: DT408
The only thing I would think problematic with braking in rub rail profiles would be where windows, doors, vents and such would intersect the lines. Having a low profile "profile" would allow the trim rings to simply compress onto them with sealer in between. A heavily raised place like a rub rail, while doing what you suggest as far as basically being a stress relief could be problematic in other places. Would be way cool though if one had the resources to stamp in the proper placement of such with the window and door locations left blank.
Old 02-21-2015, 01:57 PM   #219
Outcast's Avatar
Year: 96
Rated Cap: 75
On my 96 AmTran the rub rails are riveted on top of the body panels, just to protect them from damage. Absolutely not part of the body or structural panels, just an add on to decrease the repair cost on fleet shops. Drill them out and patch the holes and your good, or leave them for the same reason they were put there in the first place, to save the body encase you misjudge a close corner. Still not sure which way I'm going, reducing repair cost is great, but if I paint a mural on the side they will have to go first.
Outcast is offline   Reply With Quote
Old 02-21-2015, 03:24 PM   #220
sojourner's Avatar
Engine: DT408
Here's a couple pics of the access door assemblies I'm working on. I have yet to put in the hinge pins, drill the holes for mounting and cam locks, glaze, sand, prime and paint. Need 6 of them for stabilizer jack access and fuel fill access. Gonna be overseas for a couple weeks so I'll not get to work on her .
